rhysduk
Newbie level 2
rc lighting system
Hi Guys.
Im an avid RC Flyer flying both IC and SS and also Heli's.
I have a new plane in the making, and would like to add a lighting system to it. Nothing to complicated, just a few simple leds here and there to simulate a real plane.
Here's what i would like:
For the Wing Tip Lights, one will be BLUE and the other RED.
The Landing Light (which will be situated under the nose of the plane) is ideally going to be the brightest of the lights.
I was thinking of using a small 6volt 10watt Halogen Capsule. With this running of a set of 5xAAA 1000mah 1.2volt Rechargeable Batteries. This should give me around 40 or so minutes of running time from the HALOGEN CAPSULE alone.
I'm hoping to run the leds off of this source aswell, seeing as this a RC plane, weight needs to be kept to an absolute minimum.
If there are any other RC enthusiasts on here, they will know that I could run 5 or more leds off of the Rx (Receiver) battery for many hours without even worrying about the battery failing, if it did, thats one lost model.
So guys and gals, any suggestions and tips etc?
Im having trouble sourcing high power leds at a 6volt source.
Could some recommend a mcd value please?
Especially if you think i can get away with one of a very high brightness a few 10 thousand mcd's!
The key is brightness (hence my thought of using a halogen capsule for the bottom landing light.)
Many thanks guys
Rhys
Hi Guys.
- Tail Light. (Flashing)
- Wing Tip Lights (1 on Each wing)
- Landing Light.
Many thanks guys
Rhys
