rocky79
Member level 5
Hello all,
I am building an economical H-bridge circuit using minimum component counts, I found this schematics online that I want to simplify little bit, where I thought I wouldn't need trans Q6 and the 2.2K ohms resistor but instead drive the PMOS AND THE NAND GATE directly from the microcontroller pin.
That should work, unless I am missing something. Your input is appreciated.
