qweets
Junior Member level 2
hello : ) hope your having a relaxing Christmas,
I recently bought a H bridge to power a small 10v dc 800ma motor.
L6202 Datasheet pdf - DMOS FULL BRIDGE DRIVER - SGS Thomson Microelectronics
i have my h -bridge working it takes its own (IC) power from the powersupply VS pin 9 which also feeds the motor.
the voltage range for the VS input pin 9 is :
12v min
36 typical
48 max
so I have to feed the h-bridge a minimum of 12v. I am using a 18v 1.1 amp Power supply which seems to be fine. but the output for the motor from the h-bridge is aprox 17.6v ( with variable polarity) depending on the logic (DIR) inputs.
The frequency of the PWM i am using is aprox 31kh.
Am I wondering how may I reduce the h-bridges 17.6v output down to feed my 10v 800ma motor and keep the high frequency PWM intact?
Would i need a special resistor that can handle the high frequency and amps?
thanks for any help on this.
peace
12v min
36 typical
48 max
peace
