h bridge chip
I want to use a 12v car radiator fan motor as the drive motor for a large model boat. I expect it to draw approx. 15A-18A under maximum load. I want to use a PIC micro with PWM output for the motor controller. I have purchased some NTB125N02R power MOSFET's on ebay for the drive transistors. I think they should handle anything the motor should draw (if I'm reading the data sheet right, which I might not be). I think I can handle the programming side of the controller. I'm pretty good with microprocessor software. But I know very little about analog design. I've been trying to find some kind on H-bridge controller chip to handle most of the analog circuitry for me. On Google I found references to a TD340 chip that looked like it might help, but apparently they are no longer available. Can anyone recommend another H-bridge controller chip that I could put between the PIC and the MOSFET's? And could you help me with whatever other components are necessary? I was thinking about using a PIC 18F4510 since it has all four outputs necessary for the four legs of the H-bridge, but I think that with the right controller chip I might be able to use a PIC with just a single PWM output.
Could some kind soul please point me in the rigtht direction?
Thanks,
Mark
