CaptainCarp
Junior Member level 1
I started working on an already partially designed h-bridge driver for a DC brushed motor.
Long story - short, the bulk capacitors are getting very hot.
As I have never designed an h-bridge circuit before (and I don't think the original engineer did either), I started by trying to find some information related to selection of the bulk capacitor (evidently also known as the "blocking" or "DC link" or ... capacitor) for this type of application.
I have not been successful in finding a comprehensive source of information related to this and hope that someone here can lend a hand.
The circuit uses a h-bridge driver IC and discrete power MOSFETs.
The data sheet for the driver IC does not provide any guidance about selecting the bulk capacitor.
Other manufacturer's data sheets that I looked at seem to only provide general information such as "As a basic orientation, 500uF per 10A load current is recommended".
We are trying to drive a 12VDC brushed motor to about 30 Amps.
The motor must accelerate, decelerate, and reverse quickly.
I'm pretty sure that the outside software house is using the "Phase Correct" / "Centre-Symmetric" / "Center Aligned" /... PWM mode at 15kHz.
I would like to know -
1. What is the equation for determining the bulk capacitance value that I need given the allowable circuit voltage ripple (5% ?) and the drive mode / PWM frequency?
2. How does one determine the ripple current requirements of the bulk capacitors?
Is there a good equation for this or do you just start measuring current through the capacitor that was chosen (based on value / voltage ripple) and go from there?
Thank you,
CaptainCarp
Thank you,
CaptainCarp
