gsm module interfacing with at89c51
mrunknown080
hello
i am interfacing sim300 gsm module with at98c51 microcontroller. my task is to switch on and off the relay using sms.
my question is how microcontroller is going to know that gsm module had received new message.is there any interrupt or at command used for this task
please help.:sad:
also how to manage gsm module memory because its gonna fillup after some time.
you need AT Commands to communicate with gsm module.
i am bit confuse you want receive massage from gsm module if you want make relay on and off then you send command from gsm module which checked by controller and according that you can do on and off you particular relay as your required.
https://www.8051projects.net/t4941/embedded-gsm-development/interface-gsm-modem-8051.htm
https://www.edaboard.com/threads/239506/
Receive new SMS, GSM Modem will send command AT+CMTI.
so how will i utilize this command will you please share an example subroutine in c
---------- Post added at 20:22 ---------- Previous post was at 20:19 ----------
thanks i will study them then i will respond
---------- Post added at 20:35 ---------- Previous post was at 20:22 ----------
You will receive an unsolicited result code from the gsm module, means that it will send you data through serial port without any question from your side.
There is an AT command to delete read or sent messages or even all messages. Also there are AT commands for preferred sms message storage.
exactly i want to do that but i dont know the checking part,how to do that? and thanks for sharing links but all of them talk about sending a message from ucontroller but not receiving a message from gsm module and checking it if its a valid instruction or not.
please reply
---------- Post added at 20:14 ---------- Previous post was at 20:12 ----------
please reply
just see the link given by mr alexx in that link recving msg from gsm code given
and if you want receive sting from gsm say "ON" then you have to compare your sbuf data with sting
unsigned char rd1[]={"ON"};
 while(1)
  unsigned int y;//k;
 for(y=0;y<1;y++)
         while(RI==0);
         mydata[y]=SBUF;
	      delay(1);
		 P1=mydata[y];
		 RI=0;
if(P1==rd1[])
    led_d=~led_d;
Can you please post the code recd. by you?
but if i send "ON" the ucontroller will receive the msg like this
+CMGR: "REC UNREAD","xxxxxxxxxxxxxxxx","12/06/12,11:18:27+20"
ON
OK
how to handle that?
will you please post these commands here i cant find them in at commands list
