GSM module - cant get signal
Aswinth Raj
coimbatore,tamil nadu,india
when i connect my module to power the power led stay on but i cant get signal led blinking. If i am suppose to change the baud rate how am i suppose to do it. I am connecting it to my pc via serial port and using putty software.
Thank you!!
Hi kindly mention you GSM module,
every module has its own at commands for example simcom modem baud rate set command is like this ""AT+IPR=19200"
If signal led is not blinking then your sim is not in network or less signal and before change baud rate check your GSM module and try with the other sim card.
