gsm modem receive sms+interrupt+pic16f877a
coolvasanth07
Member level 1
sir,
i am doing my project gsm modem interfacing with pic 16f877a+hitech c...i have done to sending sms,,but now problam with receiving sms...so plz help me....how to i receive sms using interruts...this is my code...
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
void main()
    serial_init();
    gsm_init();
    while(1);
void gsm_init()
    delay();
    serial_string(cmd_AT);
    delay();
    serial_string(cmd_CMGF);
    delay();
    serial_string(cmd_CNMI);
    delay();
    serial_string(cmd_CMGS);
    delay();
    serial_string(msg);
    delay();
    while(TXIF==0);
    TXREG=0x1A;
void serial_init()
    TXSTA=0x20;
    RCSTA=0x90;
    SPBRG=15;
    SPEN=1;
    RCIE=1;
    GIE=1;
    PEIE=1;
void serial_string(unsigned char name[])
unsigned char i=0;
while(name[i]!='\0')
while(TXIF==0);
TXREG=name[i];
i++;
void interrupt isr(void)
    if (RCIF==1);
    Read_msg();
void Read_msg(void)
    unsigned char res_char;
    res_char=RCREG;
    RCIE=0;
    serial_string(cmd_CMGR);
    delay();
    RCIE=1;
thanks in advance..........
//Project: GSM Modem Lesson
//Programmer: Shahrulnizam Mat Rejab
//PIC: PIC16F877A, PIC16F887, PIC18F4550
//Crystal Frequency: 20MHz
//Compiler: HI-TECH C for PIC10/12/16 V9.83, PIC18 V9.65
//Last Modified: 8 August 2012
//Website: http://shahrulnizam.com
#define	UART
#define	HD44780
//#define	PCD8544
//#define	_74HC4052
#if defined (_74HC4052)
	#define	SELECT_GSM	0
#endif
#include "LibraryHardware.h"
#include "LibraryPeripheral.h"
#if defined (PCD8544)
	#include "LibraryChar.h"
#endif
#include "LibraryUniversalDisplay.h"
void pic_init(void);
unsigned char data[90],z;
unsigned int counter;
static void interrupt isr(void)
if(RCIF==1){
	counter=0;
	data[z]=RCREG;
	if(z<88) z++;}
if(TMR0IF==1){
	TMR0IF=0;
	if(counter<200) counter++;
	else z=0;
main()
{int i,j;
pic_init();								//initialize PIC
uart_init(9600);						//initialize UART
#if defined (HD44780)
	lcd_init();							//initialize LCD
#endif
	glcd_init();						//initialize GLCD
#endif
	lcd_goto(0,0);						//select first line
	lcd_string("   GSM MODEM    ");		//display string
	lcd_goto(0,1);						//select second line
	lcd_string("    EXAMPLE     ");		//display string
#endif
	glcd_goto(0,0);
	glcd_string("              ");		//display string
	glcd_string("  GSM MODEM   ");		//display string
	glcd_string("   EXAMPLE    ");		//display string
#endif
delay(5000);
	uart_select(SELECT_GSM);
#endif
for(;;){
	for(i=0;i<=89;i++) data[i]=' ';
		lcd_string("AT+CGMI         ");		//display string
	#endif
		glcd_goto(0,0);
		glcd_string("AT+CGMI       ");		//display string
	#endif
	uart_string("AT+CGMI");					//Manufacturer identification
	uart_write(0x0D);
		for(j=0;j<3000;j++){
			for(i=0;i<=15;i++) lcd_write(data[i]);}
	#endif
		for(j=0;j<300;j++){
			glcd_goto(0,1);
			for(i=0;i<42;i++) glcd_char(data[i]);}
	#endif
		lcd_string("AT+CGMM         ");		//display string
	#endif
		glcd_goto(0,0);
		glcd_string("AT+CGMM       ");		//display string
	#endif
	uart_string("AT+CGMM");					//Model identification
	uart_write(0x0D);
	#endif
		for(j=0;j<300;j++){
			glcd_goto(0,1);
	#endif
		lcd_string("AT+CGMR        ");		//display string
	#endif
		glcd_goto(0,0);
		glcd_string("AT+CGMR       ");		//display string
	#endif
	uart_string("AT+CGMR");					//Software version
	uart_write(0x0D);
	#endif
		for(j=0;j<300;j++){
			glcd_goto(0,1);
	#endif
		lcd_string("AT+CGSN        ");		//display string
	#endif
		glcd_goto(0,0);
		glcd_string("AT+CGSN       ");		//display string
	#endif
	uart_string("AT+CGSN");					//IMEI number
	uart_write(0x0D);
	#endif
		for(j=0;j<300;j++){
			glcd_goto(0,1);
	#endif
		lcd_string("ATD            ");		//display string
		lcd_string("CALLING         ");		//display string
	#endif
		glcd_goto(0,0);
		glcd_string("ATD           ");		//display string
		glcd_string("CALLING       ");		//display string
	#endif
	uart_string("ATD+60136289844;");		//Calling
	uart_write(0x0D);
	delay(8000);
		lcd_string("ATH            ");		//display string
		lcd_string("HANG UP        ");		//display string
	#endif
		glcd_goto(0,0);
		glcd_string("ATH           ");		//display string
		glcd_string("HANG UP       ");		//display string
	#endif
	uart_string("ATH");						//Hang Up
	uart_write(0x0D);
	delay(2000);
		lcd_string("AT+CMGF=1      ");		//display string
		lcd_string("TEXT MODE       ");		//display string
	#endif
		glcd_goto(0,0);
		glcd_string("AT+CMGF=1     ");		//display string
		glcd_string("TEXT MODE     ");		//display string
	#endif
	uart_string("AT+CMGF=1");				//Set text mode
	uart_write(0x0D);
	delay(2000);
		lcd_string("AT+CMGS        ");		//display string
		lcd_string("SENT MESSAGE    ");		//display string
	#endif
		glcd_goto(0,0);
		glcd_string("AT+CMGS       ");		//display string
		glcd_string("SENT MESSAGE  ");		//display string
	#endif
	uart_string("AT+CMGS=");				//Send message
	uart_write(0x22);						//"
	uart_string("+60136289844");			//Phone no
	uart_write(0x0D);						//Enter
	uart_string("Hi, I'm PIC16F887");		//Text message
	uart_string("Reply, if you receive this message");
	uart_write(0x1A);
	delay(2000);
		lcd_string("WAITING REPLY   ");		//display string
	#endif
		glcd_goto(0,0);
		glcd_string("WAITING REPLY ");		//display string
	#endif
	while(1){
		i=0;
		if(data[2]=='+') i++;
		if(data[3]=='C') i++;
		if(data[4]=='M') i++;
		if(data[5]=='T') i++;
		if(data[6]=='I') i++;
		if(i==5) break;}
		lcd_string("MESSAGE RECEIVE ");		//display string
		lcd_string("SHAHRULNIZAM.COM");		//display string
	#endif
		glcd_goto(0,0);
		glcd_string("   MESSAGE    ");		//display string
		glcd_string("   RECEIVE    ");		//display string
		glcd_string(" SHAHRULNIZAM ");		//display string
		glcd_string("   DOT COM    ");		//display string
	#endif
	while(1);
void pic_init(void)
TRISA=0b00000000;
TRISB=0b00000000;
TRISC=0b10000000;
TRISD=0b00000000;
TRISE=0b00000000;
set_digital();
#if defined (_16F877A) || defined (_16F887)
	OPTION_REG=0b00000000;
#elif defined (_18F4550)
	T0CON=0b11000000;
#endif
INTCON=0b11100000;
PIE1=0b00100000;
PORTA=0b00010000;
PORTB=0b00000000;
PORTC=0b00000000;
PORTD=0b00000000;
PORTE=0b00000000;
