GSM interface with microcontroller (code)
Vanessa Love Strawberriie
Newbie level 3
Hi, is there anybody who is able to write a keil c programming for my gsm to receive the message from what the user send to the gsm? i am using the #include<DS89C4xx.H> header and xdata.
Newbie level 3
Hi sorry i was not able to open up the code and i kind of think that this isn't what i am looking for. thanks though:)
milan.rajik
Banned
You need winrar to extract the file. It is a CodeVisionAVR Project. So, just open the .c file in notepad and copy it and paste it to keil. Remove the code related to AVR and use it for your 8051.
Newbie level 3
this is my programme code. i want to detect +CMGR and extract out the phone number and messgae. please help
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
#include<DS89C4xx.H>  //microcontroller specific library (DS89C450)
#include<absacc.h>    //XBYTE[]
#include<string.h>
#define uchar unsigned char;
/*Global Variables*/
uchar start_header='+',end_header=':';      //gsm command header
uchar xdata GSMrd[80];
uchar xdata raw_data[80];
uchar xdata infor[4];
enum sector_state {Idle,Extract} state;
uchar read_count,raw_data_count,infor_count,infor_count1, get_infor,infor_start,infor_start1;
uchar xdata extract;
void initializtion (void)
    SCON1 = 0x52;             //set serial port 1, 8-bit UART, TI Enable
    SCON0 = 0x52;
    TMOD = 0x21;              //set Timer 1 to 16-bit timer/counter
    //WDCON = 0x80;
    TH1 = 0xFD;               //set Baud Rate=9600
    //PCON=0x80;                //set SCON=1 for baud rate = 19200
    TR1=1;                    //Run Timer 1
    EA=1;
    ES0=1;
void tx(unsigned char x)
while (TI_1==0);
TI_1 = 0;
SBUF1 = x;
void tx0(unsigned char x)
  while (TI_0==0);
  TI_0 = 0;
  SBUF0 = x;
void SMSstring(unsigned char *msg)        //send string GSM to hyper terminal
  int count=0;
  while(msg[count])
    tx(msg[count++]);
//  tx(0x0D); //CR carriage return
//  tx(0x0A); //next line
void SMSstring0(unsigned char *msg)
  int count=0;
ES0=0;
  while(msg[count])
    tx0(msg[count++]);
ES0=1;
void serial_int(void) interrupt 4   //serial port 0
    ES0=0;          //disable interrupt
    if(RI_0==1)
        if(read_count==80)          //Check is array full
        read_count=0;               //Restart from position 0
        GSMrd[read_count]=SBUF0;    //Storing the data from serial buffer into array
        read_count++;               //increase the count
        //indicator=1;
        RI_0=0;                     //reset RI flag
    ES0=1;
void delay(int num)
  int i,j;
  for(i=0;i<num;i++)            //number of loop according with the given num
  for(j=0;j<1200;j++);         //num * 1200 times of looping
void read_message (void)
    if(raw_data_count != read_count)         //checking is there any unread data?
        if(raw_data_count==80) //go back to start position of array
        raw_data_count=0;
        raw_data[raw_data_count]=GSMrd[raw_data_count];//read the data
//======================= CHECK FOR "CMTI"================================
        if(raw_data[raw_data_count]==start_header)    //check for + sign
            SMSstring0("Detected + Sign");                           //prove that is detected
            infor_start=1;                                           //increment to 1 if start header is true
            raw_data[raw_data_count]=GSMrd[raw_data_count]='0';     //reset the string array of raw_data and GSmrd
            tx0(0x0D); //CR carriage return
            tx0(0x0A); //next line
        else if(infor_start==1)                    // if information (CMTI) is true
            if(raw_data[raw_data_count]==end_header)     //check for : sign
                SMSstring0("Detected : Sign");
                infor_start=0;                                         //reset infor_start back to zero
                infor_count=0;                                         //reset infor_count back to zero
                if((infor[0]=='C') && (infor[1]=='M') && (infor[2]=='T') && (infor[3]=='I'))
                    delay(100);
                    SMSstring0("AT+CMGR=1");        //Read SMS message in SIM location 1
                    extract=1;  //when message is true it will extract out the data
                    switch(raw_data[raw_data_count])
                     case: '+':
                     state=extract;
                     break;
                     default:
                     break;
                infor[0]=infor[1]=infor[2]=infor[3]='0';     //reset the CMTI information
            else if(infor_count<4)   //counter to detect CMTI
                infor[infor_count]= raw_data[raw_data_count];    //store the raw data into infor as a string
                infor_count++;                                  //every character receieve will incraese the count
         raw_data_count++;
void main(void)
    delay(200);                  //call delay
    PMR=PMR|0X81;               //power management modules for external memory
    initializtion();            //initialization        );
    SMSstring("GSM Testing ");   //to indicate system is ready for testing
    while(1)
        read_message();
