[51] GSM interface with 8051
Kenny Parmar
Newbie level 1
Newbie level 1
hello i want to make project device controller through GSM modem by SMS.
so that i am try to code this 8051 controller used in this project
i am code a one code but is not working in hardware and its finallly work in simulation protues.
can any one help me to solve this problem?
i am post my code and protues design file both.
Please fine the attachment.
//Start of COde
#include<regx52.h>
#include<string.h>
#include<absacc.h>
#include<stdlib.h>
#include<ctype.h>
#define buffer 40
#define dataport P1  // Dataport for lcd
#define port1 P2
#define port2 P0
sbit rs = P3^6;
sbit en =P3^7;
bit NewMessage=0;
sbit dv1=port1^0;
sbit dv2=port1^1;
sbit dv3=port1^2;
sbit dv4=port1^3;
sbit dv5=port1^4;
sbit dv6=port1^5;
sbit dv7=port1^6;
sbit dv8=port1^7;
sbit dv9=port2^0;
sbit dv10=port2^1;
sbit dv11=port2^2;
sbit dv12=port2^3;
sbit dv13=port2^4;
sbit dv14=port2^5;
sbit dv15=port2^6;
sbit dv16=port2^7;
void txstr(char *str);
void txchar(char value);
unsigned char abc,apt=0,count=0;
unsigned char idata msg1[buffer];
unsigned char code Response[] = "+CMTI";
// Moblie no.of Owner
unsigned char code Mob_no[]= "9409122228";
unsigned char MyBuff[20], k = 0;
bit flag1=0;
unsigned char store[10];
void delay(unsigned int msec) //Time delay function
int i,j ;
for(i=0;i<msec;i++)
  for(j=0;j<1275;j++);
void lcd_cmd(unsigned char item) //Function to send command to LCD
dataport = item;
rs= 0;
en=1;
delay(1);
en=0;
return;
void lcd_data(unsigned char item) //Funtion to send data on LCD
dataport = item;
rs= 1;
en=1;
delay(1);
en=0;
return;
void lcd_data_string(unsigned char *str) // Function to send string on LCD
int i=0;
while(str[i]!='\0')
  lcd_data(str[i]);
  i++;
  delay(10);
return;
void lcdstr(unsigned char *s)
 unsigned int l,i;
 l = strlen(s);               // get the length of string
 for(i=1;i<=l;i++)
  lcd_data(*s);              // write every char one by one
  s++;
void lcd(unsigned char str[10])  // Funtion to Initialize LCD
lcd_cmd(0x38);
lcd_cmd(0x0e);
delay(50);
lcd_cmd(0x01);
lcd_cmd(0x80);
lcd_data_string(str);
void lcd2(unsigned char str[10])  // Funtion to Initialize LCD
lcd_cmd(0x38);
lcd_cmd(0x0e);
lcd_cmd(0xc0);
delay(50);
void tx0(unsigned char x) //send data to serial port 0
	EA=0;
	SBUF=x;
	while(TI==0);
	TI=0;
	EA=1;
void SMSString(unsigned char* text) //function to send SMS using GSM modem
	while (*text)
		tx0(*text++);
void delete_msg(void)
	SMSString("AT+CMGD=1,4\r");
	delay(20);
void serial_init()
	port2=0x00;
	TL1=0XFD; //9600 @ 11.0592
	TH1=0xFD;
	TMOD=0x20;
	SCON=0x50;
	TR1=1;
void check()
		if(SBUF=='1')
		dv1=1;
		lcd("Message Received");
		lcd2("device 1 is on");
		if(SBUF=='2')
		dv2=1;
		lcd2("device 2 is on");
		if(SBUF=='3')
		dv3=1;
		lcd2("device 3 is on");
		if(SBUF=='4')
		dv4=1;
		lcd2("device 4 is on");
		}if(SBUF=='5')
		dv5=1;
		lcd2("device 5 is on");
		if(SBUF=='6')
		dv6=1;
		lcd2("device 6 is on");
		if(SBUF=='7')
		dv7=1;lcd("Message Received");
		lcd2("device 7 is on");
		if(SBUF=='8')
		dv8=1;
		lcd2("device 8 is on");
	  if(SBUF=='9')
		dv9=1;
		lcd2("device 9 is on");
		if(SBUF=='a')
		dv10=1;
		lcd2("device 10 is on");
		if(SBUF=='b')
		dv11=1;
		lcd2("device 11 is on");
		if(SBUF=='c')
		dv12=1;
		lcd2("device 12 is on");
		if(SBUF=='d')
		dv13=1;
		lcd2("device 13 is on");
		if(SBUF=='e')
		dv14=1;
		lcd2("device 14 is on");
		if(SBUF=='f')
		dv15=1;
		lcd2("device 15 is on");
		if(SBUF=='g')
		dv16=1;
		lcd2("device 16 is off");
		if(SBUF=='A')
		dv10=0;
		lcd2("device 10 is off");
		if(SBUF=='B')
		dv11=0;
		lcd2("device 11 is off");
		if(SBUF=='C')
		dv12=0;
		lcd2("device 12 is off");
		if(SBUF=='D')
		dv13=0;
		lcd2("device 13 is off");
		if(SBUF=='E')
		dv14=0;
		lcd2("device 14 is off");
		if(SBUF=='F')
		dv15=0;
		lcd2("device 15 is off");
		if(SBUF=='G')
		dv16=1;
		if(SBUF=='H')
		dv1=0;
		lcd2("device 1 is off");
		if(SBUF=='I')
		dv2=0;
		lcd2("device 2 is off");
		if(SBUF=='J')
		dv3=0;
		lcd2("device 3 is off");
		if(SBUF=='K')
		dv4=0;
		lcd2("device 4 is off");
		if(SBUF=='L')
		dv5=0;
		lcd2("device 5 is off");
		if(SBUF=='M')
		dv6=0;
		lcd2("device 6 is off");
		if(SBUF=='N')
		dv7=0;
		lcd2("device 7 is off");
		if(SBUF=='O')
		dv8=0;
		lcd2("device 8 is off");
		if(SBUF=='P')
		dv9=0;
		lcd2("device 9 is off");
	return;
 void receive_data()  	// Function to recieve data serialy from RS232 into microcontroller
  		extern unsigned char j;
	   	lcd_cmd(0x01);
		EA=0;
		while(RI==0);
		RI=0;
	//	j=SBUF;
		lcd_data(SBUF);
		EA=1;
	   	check();
		txchar(0x1a);
		delay(300);
		txstr("ATD9429944944;\r");
		delay(300);
void main()
port2=P1=port1=0x00;
lcd("home automation");
lcd2("system");
serial_init();
   // Configure interrupt 0 for falling edge on /INT0 (P3.2)
SMSString("AT\r\n"); // AT commands to initialize gsm modem
delay(20);
SMSString( "ATe0\r\n"); // turn off echo
delay(20);
SMSString( "AT&W\r\n"); // save settings
delay(20);
SMSString( "AT+CMGF=1\r\n"); // select text mode for sms
delay(20);
SMSString( "AT+CNMI=1,1,0,0,0\r\n"); // notification of new sms
lcd_cmd(0x01); //Clear LCD display.
 while(1)
delay(20);
SMSString("AT+CMGL=REC UNREAD\r\n");   //new message indicate
SMSString("AT+CMGL=0\r\n");				//
SMSString("AT+CMGR=1\r\n");
receive_data();
SMSString("AT+CMGL=1\r\n");
 receive_data();
delay(20);
	SBUF=value;
	while(TI==0); // Pole TI flag for complete transmission
	TI=0;
 	while(*str)
	 	txchar(*str);
		str++;
		delay(100);
	*str='\0';
	return;
