GSM base parents query system
abdulrehman123
Newbie level 1
Newbie level 1
what are the at commands of gsm900? how can i send and receive messages to gsm through at commands?kindly , give me all material... THANKX in advance
First install an application "Tera-Term" or X-CTU or Hyperterminal
Connect you GSM Module to PC
Download datasheet of Sim900 "AT Command" there you can get all the list of AT Command
But for simplicity
first type "AT" follwed by Carriage Return and Line feed , In the terminal just press enter after "AT" you will get OK as response
Same way for calling insert a GSM Sim card
and type "AT+COPS?" press Enter you will get the response regarding the operator name
For Call ATDphone_number; and ENTER ;// Call will be made
AT+CMGF=1 // Configures as Text Mode
AT+CMGS="phone_number";  ENter
then you will get the response like this
">" then type your message and after that
press
"ctrl+Z"   // This will send the message to the number you entered
SO these are the primary ones try more and the same thing with microcontroller
Good luck
First to check the SIM900 module, type AT then hit enter key. It will reply OK.
For sending sms,
AT+CMGF=1 >>Enter
AT+CMGS="xxxxxxxxxxxx" >>Enter
The modem will reply with the symbol '>'
Then type the message then ctrl+z
thats all
