gsg
Junior Member level 1
Hi
I'm using a 7805 to power a dsPIC33 controller PCB. I've built the 7805 circuit separately on a breadboard. It gives an exact 5v o/p on the breadboard but when i connect ground pin of the controller PCB to it the output goes to around 3.5v and then starts reducing slowly. It means that the ground pin is giving some voltage.
I have checked the PIC board for connectivity and changed all the capacitors. How can I debug this circuit?
PS- the PIC board contains a 3.3v regulator (LE33CD),and rs232 port, two MAX3096 ICs and four isocoupler ICs.
Please help.
Please help.
