gary36
Full Member level 4
I have a system consisting of two PCBs connected via Flat ribbon connectors. Checked the continuity of the ground and it is ok. Resistance is around 0.6 ohms. When I power ON, I see that there is 100mV potential difference between the two PCB grounds. What could be the reasons? I am unable to post the layout or the schematics at this point of time. I would highly appreciate if someone can explain the potential reasons, why the ground might lift up?
