Yaro
Newbie level 6
I've found a Gray Couter code already written for a FIFO code. But it gives me an error.
Here's the code:
The error I've is:
Arguments have widths 4 and 3, they should match on GrayCount_out.
How I can fix this error?
Here's the code:
-- Function : Code Gray counter.
-- Coder : Alex Claros F.
-- Date : 15/May/2005.
-- Translator : Alexander H Pham (VHDL)
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity GrayCounter is
generic (
COUNTER_WIDTH :integer := 4
port ( --'Gray' code count output.
GrayCount_out :out std_logic_vector (COUNTER_WIDTH-1 downto 0);
Enable_in :in std_logic; -- Count enable.
Clear_in :in std_logic; -- Count reset.
clk :in std_logic -- Input clock
end entity;
architecture rtl of GrayCounter is
signal BinaryCount :std_logic_vector (COUNTER_WIDTH-1 downto 0);
begin
process (clk) begin
if (rising_edge(clk)) then
if (Clear_in = '1') then
--Gray count begins @ '1' with
BinaryCount <= conv_std_logic_vector(1, COUNTER_WIDTH);
GrayCount_out <= (others=>'0');
-- first 'Enable_in'.
elsif (Enable_in = '1') then
BinaryCount <= BinaryCount + 1;
GrayCount_out <= (BinaryCount(COUNTER_WIDTH-1) &
BinaryCount(COUNTER_WIDTH-2 downto 0) xor
BinaryCount(COUNTER_WIDTH-1 downto 1));
end if;
end if;
end process;
end architecture;
The error I've is:
