Graphic lcd user interface design tool
BEA
Junior Member level 2
Hi all,
I am about to design a new menusystem for a graphic lcd. I work with a MSP430 controller and a 64x128 pixel display. I'm using RAMTEX display routines. The menu system handles parameters, temperatures, status...
Last time I did a meny system with 100 rows I ended up in several 1000 lines of C-structures for bahavior description and a excel sheet for multilang text input + a program for excel to C-source conversion etc.
My quiestion is if there is any design tools availible that helps me designing it? Or do I have to develop a tool by my self ? The design tool should have C-source output.
Hi BEA,
I don't want to change your design approach to graphic LCD. If you did used RAMTEX display routine means you afford to spend some money since these display routines are not available on "usual channels"
However you can try using Graphical Operating System in Silicon that reduces the development time, as well as the hardware-software integration phase in embedded systems.
Take a look at this solution even if you've never used an HTML editor before.
I'm not trying to advertise the product. Just reveal his strength.
Only a solution.
