Hello Friends ,
I have a query .
I need to send data from microcontroller to gsm modem which sends data to a web server.
Now I m sending the following command:
AT+HTTPPARA="URL","http://xyz.in/abc.php?v1=436&v2=001&v3=031&v4='LOW'&v5='FAIL'&v6='OK'&v7='HIGH'&v8='CLOSE'&v9='BIGT17662'"
AT+HTTPACTION=0
I am sending the data to a table in mysql database.
The problem is when the table is initially empty , The response time from the server is fast.i.e:
+HTTPACTION: 0,200,210 (response from the server after i send AT+HTTPACTION=0 ) command. ----> response time 1-2 seconds...
As i send data again and again the response time increases.
After sending around 50 times of the similar data.
The response time increases to about 15-16 seconds.
+HTTPACTION: 0,200,8050 (response from the server after i send AT+HTTPACTION=0 ) command. ----> response time 15-16 seconds...
I have to continuously keep on sending the data and read the response also from the server
What can be done so that i can have instant response 2-3 seconds every time.
1.Can i flush out the server data buffer after sending every command , will it impact the data writing in the table?
2. If it can be done How do i do it?
