Jul 20, 2007 #1 A anil555 Newbie level 5 Joined Jul 20, 2007 Messages 8 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,344 Hi all, I am trying to design a amplifier using BJT. While changing the property of the BJT it asks for parameter like model name, area, region etc. I am not able to figure out what the model name is. I tried NPN, NPNMOD but to no avail. moreover it is asking for a .m file...... If anybody has any idea about it, please reply to me Anil
Jul 20, 2007 #2 B bobchentan Junior Member level 3 Joined Aug 11, 2006 Messages 31 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,470 you should specify the model file, which will give you the model name for the transistor
Jul 20, 2007 #3 A anil555 Newbie level 5 Joined Jul 20, 2007 Messages 8 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,344 Thanks for the reply........ I am working with cadence SpectreS. I think i have all MOS Model files only. IS there any way by which i can get BJT model files? Anil
Jul 21, 2007 #4 H hazemafify Advanced Member level 4 Joined Dec 3, 2006 Messages 102 Helped 5 Reputation 10 Reaction score 1 Trophy points 1,298 Activity points 1,903 I recommend you to use NMOS instead of using NPN.
Jul 21, 2007 #5 A anil555 Newbie level 5 Joined Jul 20, 2007 Messages 8 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,344 The thing is that i am simulating a MMIC amplifier. I got its Circuit diagram from the datasheet and it uses a BJT.
