debi2
Newbie level 1
Hello!
I'd like to ask for help to repair my tablet.
It is Goclever 9,7". Unfortunately I'm not sure which model is it, probably it is R972, R973 or R974.
The problem regards battery charging. Original battery was damaged and has to be removed. I put the new one with similar parameters (7800mAh instaed of 8000mAh, 3,7V).
Tablet shows the battery level and shows info than charging is in progress, but physically battery is not charging.
I measured the voltage on the battery connections when AC power adapter is on and off - in both cases was approx. 3,7V. As I know, during charging it should be approx. 4,5V, am I correct?
I've tried to measure current also. After shut down tablet the amperemeter was plugged in the positive electrode of the battery and then AC power adaptor was connected. Current was 0.
I suppose this proves that device doesn't physically apply charging voltage to the battery.
Any ideas what to do now? I will be gratefull for any help.
Thanks!
Thanks!
