gm/Id Vs Vgscurve of a mosfet
arunkumar446
Full Member level 3
mosfet gm
how to get gm/Id Vs Vgs plot using cadence spectre simulator. reply asap, thanks in advance.
gm mosfet
Run DC analysis. Sweeping variable is Vgs (just connect Vgs to Vdc and sweep Vdc voltage).
Then using calculator take IS of drain or drain current. Click "Special function" and select "deriv"
Then click "x<->y", then "/"(devide) and "erplot"
how to plot gm of a mosfet in cadence
Hi Fom, can you tell me how to plot ft Vs Vgs.
and how to do the noise analysis in cadence spectre, i would like to see flicker noise and thermal noise produced by an mosfet.
if possible one more thing-> how to plot intrinsic gain of a mosfet Verses Vgs.
Thanks in advance.
I also want to know how to plot gm/id vs vgs(vov) in spectre~~~FOM gave the method, but i still do not get the curve~~~
gm/Id Vs Vgs curve of a mosfet
How can I extract gm/Id vs Vgs curve in hspice?
