VASANSNS
Junior Member level 1
Hello everybody,
I am a newbie in the field of analog design. I accidentally stumbled upon the gm/id methodology and found it to be pretty useful and many reviews say that it is comparatively better than the traditional design considering overdrive voltages especially for hand calculations. But i am having issues starting with this design. For example when i don't know what is the aspect ratios is need, i don't know how to generate the gm/id vs id/(W/L) curve. Also i read that the curves can be obtained from models or from experimental data. How do i obtain them or generate them from the BSIM model. If anybody has a document explaining it step by step i kindly request you guys to share it with me. Any other documentation is also welcomed .
Regards
Vasan SNS
Regards
Vasan SNS
