glitch in the output of digital logic
kickbeer
Full Member level 3
glitch digital logic
I've just simulated a folding & interpolating ADC and found a glitch around 0.5 V after an EX-OR logic in my digital part. In the attachment, V(c07) and V(c23) are the input and V(out_07_23) is the output of EX-OR. As you can see in waveform, there is a glitch of 0.5 V(at time 0.3 us) of the output of EX-OR.I'm wondering how this happened because both the inputs travel at the same speed. How to get rid of this problem? I've been working on this since two days.
mandar_mahajan
Full Member level 2
mumbai
basics of glitch + digital logic
Dear,
It is very hard to tell u from the w/f's u have posted.
Post ur schematic of circuit on ehich u r working.
Must be a ground related issue.
TRY THIS:
Just check the voltage bet'n main ground & the Analog ground of ADC.
Analog & digital gnd must be different.
Regards
mandar
tony_taoyh
Full Member level 2
For the digital logic, you can not assume they are travelling at same speed: process variation, state dependent delay, and so on.
To remove those gritches, you may:
1) Change the method to generate the input signals.
For example, some gray coded counter may help.
2) You may add one latch after the logic.==> idea of sync circuit design.
3) Add enough delay for one of the input. (last solution.)
Hope helpful.
    kickbeer
kickbeer
Full Member level 3
mandar_mahajan said:
Dear,
TRY THIS:
Regards
mandar
Hi mandar,
Thanks very much for willing to helpm me.
I wanted to post the schematic but is is too large and may not helpful in solving that problem. Do you have LTSpice? I'll post it if u have so that you can simulate and see yourself more glitches after the digital logic. About the gnd, i think it is integrated in the EX-OR block because i took that directly from LTSpice library. See attachment.
mandar_mahajan
Full Member level 2
mumbai
Hi Kickbeer,
Sorry to say but i dont have LTspice & dont know much abt it.
I am not able to understand how ur dealing with ur ckt?
Which ADC u r using?
kickbeer
Full Member level 3
Hi Kickbeer,
LTSpice is a free software form linear technology and it is very easy to use. You can download it from here:
https://www.linear.com/designtools/software/ltspice.jsp
Once you downloaded you can directly run my ADC if you want. Anyway i'm using 8-bit Folding and Interpolating ADC.
dick_freebird
Advanced Member level 5
USA
I am guessing that with the dual outputs, these are a
CML or SCL logic family.
What I see is that the common-mode voltage of the
two logic inputs you show, is jerked abruptly at a couple
of timepoints. This to me is abnormal and I think maybe
you have some misdefined input signals that are
jacking these gates' operating point (hence timing
and output drive / levels) around.
    kickbeer
