GLCD PCF8833 with ARM LPC2148
hbaocr
Full Member level 4
Hochiminh City university of technology (VietNam)
pcf8833
hello;
I have project using GLCD( phillip chipset use for NOKIA 6100)! And I met a big problem when coding with it.I don't know why my code incorrect.Here that code
// LPC2148    ----->  GLCD(6100 display PCF8833)
// MOSI(P0.6) ------>  DATA(pin 3 )
// SCK(P0.4)  ------>  SCK
// MISO(P0.5) -------  NC
// P0.2    	  ------>  RS
// P0.7) ------------> CS
//P0.3--------------->Blink
#include "LPC214x.H"
/* pototype  section */                               	// LPC2148 MPU Register
//define for LCD
          Command of LCD NOKIA6100(phillips chipset)
#define NOP       0x00 // nop
#define SWRESET    0x01 // software reset
#define BSTROFF    0x02 // booster voltage OFF
#define BSTRON       0x03 // booster voltage ON
#define RDDIDIF    0x04 // read display identification
#define RDDST       0x09 // read display status
#define SLEEPIN    0x10 // sleep in
#define SLEEPOUT    0x11 // sleep out
#define PTLON       0x12 // partial display mode
#define NORON       0x13 // display normal mode
#define INVOFF      0x20 // inversion OFF
#define INVON       0x21 // inversion ON
#define DALO       0x22 // all pixel OFF
#define DAL       0x23 // all pixel ON
#define SETCON       0x25 // write contrast
#define DISPOFF    0x28 // display OFF
#define DISPON       0x29 // display ON
#define CASET       0x2A // column address set
#define PASET       0x2B // page address set
#define RAMWR       0x2C // memory write
#define RGBSET       0x2D // colour set
#define PTLAR       0x30 // partial area
#define VSCRDEF    0x33 // vertical scrolling definition
#define TEOFF       0x34 // test mode
#define TEON       0x35 // test mode
#define MADCTL       0x36 // memory access control
#define SEP       0x37 // vertical scrolling start address
#define IDMOFF       0x38 // idle mode OFF
#define IDMON       0x39 // idle mode ON
#define COLMOD       0x3A // interface pixel format
#define SETVOP       0xB0 // set Vop
#define BRS       0xB4 // bottom row swap
#define TRS       0xB6 // top row swap
#define DISCTR       0xB9 // display control
#define DOR       0xBA // data order
#define TCDFE       0xBD // enable/disable DF temperature compensation
#define TCVOPE       0xBF // enable/disable Vop temp comp
#define EC          0xC0 // internal or external oscillator
#define SETMUL       0xC2 // set multiplication factor
#define TCVOPAB    0xC3 // set TCVOP slopes A and B
#define TCVOPCD    0xC4 // set TCVOP slopes c and d
#define TCDF       0xC5 // set divider frequency
#define DF8COLOR    0xC6 // set divider frequency 8-color mode
#define SETBS       0xC7 // set bias system
#define RDTEMP       0xC8 // temperature read back
#define NLI       0xC9 // n-line inversion
#define RDID1       0xDA // read ID1
#define RDID2       0xDB // read ID2
#define RDID3       0xDC // read ID3
//define pin
#define RS (1<<2)
#define CS (1<<7)
#define BL (1<<3)
#define SDA       (1<<6) //MOSI
#define CLK       (1<<4) //CLK
//define program
//          Program definition
#define CS0 IOCLR0 = CS
#define CS1 IOSET0 = CS
#define CLK0 IOCLR0 = CLK
#define CLK1 IOSET0 = CLK
#define SDA0 IOCLR0 = SDA
#define SDA1 IOSET0 = SDA
#define RESET0 IOCLR0 = RS
#define RESET1 IOSET0 = RS
//          Program prototype
void lcd_init(void);
void spi_init(void);
void sendData(unsigned char data);
void sendCMD(unsigned char com);
void LCD_put_pixel(unsigned char color, unsigned char x, unsigned char y);
void delay_ms(unsigned long int);						// Delay Time Function
//main function
int main(void)
unsigned int i;
//int
IODIR0 =  CS|CLK|SDA|RS;
lcd_init();
while(1)
for(i=1;i<131;i++)
LCD_put_pixel(0xFC,i,50);
//test code
//=============spi int==================
void spi_init(void)
	PINSEL0 |= 0x00001500; // set port0.4-0.6 SPI0
 // SPI0 initial function LCD6100
  	S0SPCCR = 8;       // SPI0 clk = VPB clk /S0PCCR
                 //  7.5 MHz = 60 MHz /8
 // SPI0 Register control
  	S0SPCR = 0x00000924; // 9 bit data
     					// CPHA=0, CPOL=0
                       // MPU master
                      // MSB first
                     // SPIF interrupts unable
//=============end function==============
          LCD initial Function
void lcd_init(void)
int i = 0;
  spi_init();
  /*** Hardware Reset LCD ***/
  RESET0;
  delay_ms(10);
  RESET1;
  delay_ms(10);
  /*** Initial state ***/
  CS0;				   // cho phep LCD
  sendCMD(SWRESET);    // Software Reset LCD
  delay_ms(10);
  sendCMD(SLEEPOUT); // Sleep out
  delay_ms(10);
  //sendCMD(INVON);	//seem to be requires for this controller
  sendCMD(COLMOD);   // 8 bit color
  sendData(0x02);
  sendCMD(NORON);    // Normal Display
  sendCMD(MADCTL);    //   memory access control
  sendData(0x40);    // Miror X
  sendCMD(SETCON);    // set contrast
  sendData(63);
  delay_ms(10);
  sendCMD(DISPON);    // Display ON
  delay_ms(10);
   /*** Set Black Coulour to Backgound ***/
   sendCMD(CASET);
   sendData(0);
   sendData(131);
   sendCMD(PASET);
   sendData(1);
   sendData(131);
   sendCMD(RAMWR);
   for(i=0;i<(131*131);i++)
      sendData(0);
          Send command to LCD Function
   	 CS0;// chip select enable
     S0SPDR = com & ~0x0100;// For Command MSB "LOW"
     while((S0SPSR & 0x80)!= 0x80){;;}   // Wait SPIF = 1 (SPI Send Complete)
     CS1; //unselect
          Send Data to LCd function
  CS0;
  S0SPDR  = data | 0x0100;// For Data MSB must "HIGH"
  CS1;
          LCD plot pixel on LCD Function
  sendCMD(PASET);   // page start/end ram  = Row
  sendData(y);
  sendData(131);
  sendCMD(CASET);   // column start/end ram = Colum
  sendData(x);
  sendData(131);
  sendCMD(RAMWR);    // write DATA
  sendData(color);
/* Delay Time Function */
void delay_ms(unsigned long int count1)
unsigned int i,k;
k=count1*2600;
  for(i=0;i<k;i++);							// Loop Decrease Counter
glcd arm
you should describe your problem exactly. so people can help you.
