GLCD logic supply problem
mamech
Full Member level 3
Hello
I have a winstar WDG0151 GLCD (see attachments for Datasheet), and I am trying to connect it to a pic micro.
I have seen a lot of schematics for GLCDs connections to microcontrollers over the net, so I noticed that they connect always a potentiometer with one of its termainals connected to Gnd
the second terminal to Vo and the third terminal connected to Vee.
But in the data sheet I found that the first terminal is connected to Vcc not to Gnd, while the second is also connected to Vo and the third to Vee.
Actually I did not find any other schematic does this (I mean connecting the first terminal to vcc)
all of the schematics I saw , the fist pin is grounded.
I am afraid that I misunderstand something in the datasheet, thus I may burn the GLCD if I do that.
Can anyone tell me if I am getting the matter correctly?
  • WDG0151-TMI-V#N00.pdf
The diagram seem clear, just looked at a similar glcd and it shows exactly the same configuration.
As long as you use a 20k pot and start off in the mid position doubt you can do much harm.
To be safe, fit a 250ma fuse on the output of your 5v regulator and monitor the current with your meter as you slowly turn the pot.
https://www.sparkfun.com/datasheets/LCD/GDM12864H.pdf
Reactions: mamech
    mamech
