GLCD 128x64 data sheet in detail and code without librery for pic18f4550 plz sr.....
dharmendrapies
Newbie level 2
Newbie level 2
hi plz send glcd datasheet
and code without lib......use...
find on net but not found plz help me.................
Re: GLCD 128x64 data sheet in detail and code without librery for pic18f4550 plz sr.
What is your product name ???
i am learning pic18f4550 on bord GLCD 128x64 pin digram
1 CS1
2 CS2
3 GND
4 VCC +5V
5 VO
6 RS
7 R/W
8 EN
9 D0
10 D1
11
12
13
14
15
16 D7
17 RST
18 Vee
19 LED+
20 LED-
Afraid just giving the glcd pin out is of little use, its the glcd name/code and controller type that is needed as there are many different types out there , some needing very different programming to work them.
You also need to say what programming language you are using with the 4550.
Sounds like you have a development board with a glcd on it, yes ? - if so whos board is it and which model ?
Is that NOKIA 5110 LCD? Try this code for CCS.
//_______________________________________________________________________________________________________
//		PIC to Nokia 3310 LCD (PCD8544) driving routines written Hi-Tech C
//		written by Ramandeep Singh ฉ2004
//		with help from Michel Bavin's EEPROM to 3310 LCD routines
//		www.spiralbrain.tk or  http://67.15.78.55/~spiral/
//		spiralbrain@yahoo.com
//		Date: 21 Nov 2004
//	Usage : Include 3310.c in the main project file, include delay.h and delay.c
//	in the main file, define the PIC pins to be used in this file, in the main
//	code file call init_nokia(); to initialise the LCD
//	nokia_gotoxy(0,0);
//	nokia_printchar('D');
//	nokia_printmessage("hello can you really read this?");
// define PIC <> LCD ports here
#BYTE nok_sclk = PIN_B0
#BYTE nok_sda  = PIN_B1
#BYTE nok_cs   = PIN_B2
#BYTE nok_dc   = PIN_B3
#BYTE nok_res  = PIN_B4
typedef unsigned char 		BYTE;		/* Unsigned 8-bit */
typedef unsigned char 		byte;		/* Unsigned 8-bit */
unsigned char charsel,i,c;
unsigned char bytefornokia,testbyte;
static byte  LcdCache [ 5 ];
char   LcdCacheIdx;
//functions
void init_nokia(void);				// initialisation
void nokia_write_command(void);			// nokia lcd subroutines
void nokia_write_dorc(void);
void nokia_build_DDRAM(void);			//Build DDRAM
void nokia_write_data(void);			//write Data
void nokia_gotoxy(byte xnokia, byte ynokia);	// go to x,y on the LCD
void nokia_printchar(byte c);			// print a char at the current position
void nokia_printmessage(const char* message);	// print a string at the current position
void table_to_nokialcd(void);			// write from table to nokia lcd
//________________________________________________________________________________________________________________________
  static const char FontLookup [][5] =
    { 0x00, 0x00, 0x00, 0x00, 0x00 },  // sp
    { 0x00, 0x00, 0x2f, 0x00, 0x00 },   // !
    { 0x00, 0x07, 0x00, 0x07, 0x00 },   // "
    { 0x14, 0x7f, 0x14, 0x7f, 0x14 },   // #
    { 0x24, 0x2a, 0x7f, 0x2a, 0x12 },   // $
    { 0xc4, 0xc8, 0x10, 0x26, 0x46 },   // %
    { 0x36, 0x49, 0x55, 0x22, 0x50 },   // &
    { 0x00, 0x05, 0x03, 0x00, 0x00 },   // '
    { 0x00, 0x1c, 0x22, 0x41, 0x00 },   // (
    { 0x00, 0x41, 0x22, 0x1c, 0x00 },   // )
    { 0x14, 0x08, 0x3E, 0x08, 0x14 },   // *
    { 0x08, 0x08, 0x3E, 0x08, 0x08 },   // +
    { 0x00, 0x00, 0x50, 0x30, 0x00 },   // ,
    { 0x10, 0x10, 0x10, 0x10, 0x10 },   // -
    { 0x00, 0x60, 0x60, 0x00, 0x00 },   // .
    { 0x20, 0x10, 0x08, 0x04, 0x02 },   // /
    { 0x3E, 0x51, 0x49, 0x45, 0x3E },   // 0
    { 0x00, 0x42, 0x7F, 0x40, 0x00 },   // 1
    { 0x42, 0x61, 0x51, 0x49, 0x46 },   // 2
    { 0x21, 0x41, 0x45, 0x4B, 0x31 },   // 3
    { 0x18, 0x14, 0x12, 0x7F, 0x10 },   // 4
    { 0x27, 0x45, 0x45, 0x45, 0x39 },   // 5
    { 0x3C, 0x4A, 0x49, 0x49, 0x30 },   // 6
    { 0x01, 0x71, 0x09, 0x05, 0x03 },   // 7
    { 0x36, 0x49, 0x49, 0x49, 0x36 },   // 8
    { 0x06, 0x49, 0x49, 0x29, 0x1E },   // 9
    { 0x00, 0x36, 0x36, 0x00, 0x00 },   // :
    { 0x00, 0x56, 0x36, 0x00, 0x00 },   // ;
    { 0x08, 0x14, 0x22, 0x41, 0x00 },   // <
    { 0x14, 0x14, 0x14, 0x14, 0x14 },   // =
    { 0x00, 0x41, 0x22, 0x14, 0x08 },   // >
    { 0x02, 0x01, 0x51, 0x09, 0x06 },   // ?
    { 0x32, 0x49, 0x59, 0x51, 0x3E },   // @
    { 0x7E, 0x11, 0x11, 0x11, 0x7E },   // A
    { 0x7F, 0x49, 0x49, 0x49, 0x36 },   // B
    { 0x3E, 0x41, 0x41, 0x41, 0x22 },   // C
    { 0x7F, 0x41, 0x41, 0x22, 0x1C },   // D
    { 0x7F, 0x49, 0x49, 0x49, 0x41 },   // E
    { 0x7F, 0x09, 0x09, 0x09, 0x01 },   // F
    { 0x3E, 0x41, 0x49, 0x49, 0x7A },   // G
    { 0x7F, 0x08, 0x08, 0x08, 0x7F },   // H
    { 0x00, 0x41, 0x7F, 0x41, 0x00 },   // I
    { 0x20, 0x40, 0x41, 0x3F, 0x01 },   // J
    { 0x7F, 0x08, 0x14, 0x22, 0x41 },   // K
    { 0x7F, 0x40, 0x40, 0x40, 0x40 },   // L
    { 0x7F, 0x02, 0x0C, 0x02, 0x7F },   // M
    { 0x7F, 0x04, 0x08, 0x10, 0x7F },   // N
    { 0x3E, 0x41, 0x41, 0x41, 0x3E },   // O
    { 0x7F, 0x09, 0x09, 0x09, 0x06 },   // P
    { 0x3E, 0x41, 0x51, 0x21, 0x5E },   // Q
    { 0x7F, 0x09, 0x19, 0x29, 0x46 },   // R
    { 0x46, 0x49, 0x49, 0x49, 0x31 },   // S
    { 0x01, 0x01, 0x7F, 0x01, 0x01 },   // T
    { 0x3F, 0x40, 0x40, 0x40, 0x3F },   // U
    { 0x1F, 0x20, 0x40, 0x20, 0x1F },   // V
    { 0x3F, 0x40, 0x38, 0x40, 0x3F },   // W
    { 0x63, 0x14, 0x08, 0x14, 0x63 },   // X
    { 0x07, 0x08, 0x70, 0x08, 0x07 },   // Y
    { 0x61, 0x51, 0x49, 0x45, 0x43 },   // Z
    { 0x00, 0x7F, 0x41, 0x41, 0x00 },   // [
    { 0x55, 0x2A, 0x55, 0x2A, 0x55 },   // 55
    { 0x00, 0x41, 0x41, 0x7F, 0x00 },   // ]
    { 0x04, 0x02, 0x01, 0x02, 0x04 },   // ^
    { 0x40, 0x40, 0x40, 0x40, 0x40 },   // _
    { 0x00, 0x01, 0x02, 0x04, 0x00 },   // '
    { 0x20, 0x54, 0x54, 0x54, 0x78 },   // a
    { 0x7F, 0x48, 0x44, 0x44, 0x38 },   // b
    { 0x38, 0x44, 0x44, 0x44, 0x20 },   // c
    { 0x38, 0x44, 0x44, 0x48, 0x7F },   // d
    { 0x38, 0x54, 0x54, 0x54, 0x18 },   // e
    { 0x08, 0x7E, 0x09, 0x01, 0x02 },   // f
    { 0x0C, 0x52, 0x52, 0x52, 0x3E },   // g
    { 0x7F, 0x08, 0x04, 0x04, 0x78 },   // h
    { 0x00, 0x44, 0x7D, 0x40, 0x00 },   // i
    { 0x20, 0x40, 0x44, 0x3D, 0x00 },   // j
    { 0x7F, 0x10, 0x28, 0x44, 0x00 },   // k
    { 0x00, 0x41, 0x7F, 0x40, 0x00 },   // l
    { 0x7C, 0x04, 0x18, 0x04, 0x78 },   // m
    { 0x7C, 0x08, 0x04, 0x04, 0x78 },   // n
    { 0x38, 0x44, 0x44, 0x44, 0x38 },   // o
    { 0x7C, 0x14, 0x14, 0x14, 0x08 },   // p
    { 0x08, 0x14, 0x14, 0x18, 0x7C },   // q
    { 0x7C, 0x08, 0x04, 0x04, 0x08 },   // r
    { 0x48, 0x54, 0x54, 0x54, 0x20 },   // s
    { 0x04, 0x3F, 0x44, 0x40, 0x20 },   // t
    { 0x3C, 0x40, 0x40, 0x20, 0x7C },   // u
    { 0x1C, 0x20, 0x40, 0x20, 0x1C },   // v
    { 0x3C, 0x40, 0x30, 0x40, 0x3C },   // w
    { 0x44, 0x28, 0x10, 0x28, 0x44 },   // x
    { 0x0C, 0x50, 0x50, 0x50, 0x3C },   // y
    { 0x44, 0x64, 0x54, 0x4C, 0x44 }    // z
//__________________________________________________________________________________________________________________________
	// nokia LCD init
		nok_dc=1;			// bytes are stored in the display data ram, address counter, incremented automatically
		nok_cs=1;			// chip disabled
		DelayMs(1);
		nok_res=0;			// reset chip during 250ms
		DelayMs(1);
		nok_res=1;
		bytefornokia=0x21;		// set extins extended instruction set
		nokia_write_command();
		bytefornokia=0xBf;		// Vop  was 0xc5 // better is 0xa0
		bytefornokia=0x04;		// temp coefficent
		bytefornokia=0x14;		// bias
		bytefornokia=0x20;		// horizontal mode from left to right, X axe are incremented automatically , 0x22 for vertical addressing ,back on normal instruction set too 0x20 for horizontal
		bytefornokia=0x09;		// all on
		bytefornokia=0x0C;		// ????
		DelayMs(250);
		DelayMs(250);
 		nokia_build_DDRAM();	  	// reset DDRAM, otherwise the lcd is blurred with random pixels
		DelayMs(10);
		bytefornokia=0x08;		// mod control blank change (all off)
		DelayMs(10);
		bytefornokia=0x0c;		// mod control normal change
		nokia_gotoxy(0,0);
nok_dc=0;	// byte is a command it is read with the eight SCLK pulse
nok_cs=0;	// chip enabled
nokia_write_dorc();
nok_dc=1;
nokia_write_dorc();
void nokia_write_dorc(void)			// serial write data or command subroutine
for (c=2;c>0;c--) {
		nok_sclk=0;
		if ((bytefornokia&0x80)==0){
		nok_sda=0;
		else {
		nok_sda=1;
		nok_sclk=1;
		bytefornokia=bytefornokia<<1;
void nokia_build_DDRAM(void)	// clear all DDRAM (set all bits to zero)
signed char ch, cm, cl;
nok_sda=0;
nok_dc=1;
nok_cs=0;
for (ch=2;ch>0;ch--){				// 6 rows
	for (cm=2;cm>0;cm--){			// 84 columns
		for (cl=2;cl>0;cl--){		// 8 pixels
			nok_sclk=0;
			nok_sclk=1;
nok_cs=1;
void nokia_gotoxy (byte xnokia, byte ynokia)	// Nokia LCD Position cursor
		bytefornokia=(0x40|(ynokia&0x07));		// Y axe initialisation: 0100 0yyy
		bytefornokia=(0x80|(xnokia&0x7f));		// X axe initialisation: 1xxx xxxx
void nokia_printmessage(const char* message)	// Write message to LCD (C string type)
	while (*message)							// Look for end of string
		nokia_printchar(*message++);			//
void nokia_printchar(byte c)					// Write 1 character to LCD
charsel=c;
table_to_nokialcd();
void menu_nokia_printmessage(const char* message)	// Write message to LCD (C string type)
	nokia_gotoxy (0,5);
void table_to_nokialcd(void)	//
        for ( i = 0; i < 5; i++ )
            LcdCache[i] = FontLookup[charsel - 32][i] << 1;
	bytefornokia=LcdCache[i];	//	Write D at 30,0
	nokia_write_data();		// send data to nokia
//	DelayMs(15);
	bytefornokia=0x00;
char   LcdCacheIdx;
//functions
	// nokia LCD init
		DelayMs(1);
		DelayMs(1);
		nok_res=1;
		DelayMs(250);
		DelayMs(250);
		DelayMs(10);
		DelayMs(10);
		nokia_gotoxy(0,0);
nokia_write_dorc();
nok_dc=1;
nokia_write_dorc();
for (c=2;c>0;c--) {
		nok_sclk=0;
		nok_sda=0;
		else {
		nok_sda=1;
		nok_sclk=1;
nok_sda=0;
nok_dc=1;
nok_cs=0;
			nok_sclk=0;
			nok_sclk=1;
nok_cs=1;
charsel=c;
	nokia_gotoxy (0,5);
//	DelayMs(15);
	bytefornokia=0x00;
Thread title is GLCD 128x64.
I must admit this thread is awesome. :smile:
Best regards,
Peter
:wink:
