Reading Position Data from AS33-M42M Encoder
Jooje
Newbie
Newbie level 3
Hi friends,
I'm trying to read data from my Broadcom AS33-M42M absolute encoder. According to the datasheet, it uses RS-485 as the physical layer, but I couldn't find any details about the communication protocol or the command structure required to request data from the encoder. There are no clear instructions on what commands I need to send or how the data is structured in the response.
Does anyone have experience with this encoder or know where I can find the RS-485 protocol details? Is there a separate RS-485 software specification document from Broadcom that provides the necessary information? Any guidance or sample commands would be greatly appreciated!
Thanks in advance!
  • AS33-M42M-DS102.pdf
Hello!
You can find detail of BiSS protocol at this link.
You can download the full protocol description and application notes.
It's also possible to bit-bang it, and just in case, I think TI has some CPUs
with BiSS interface integrated. At least I heard about it, and possibly also
Renesas, not sure.
Among the merits of BiSS protocol:
- Duplex connection: you can send command without interrupting the data flow as you would
do with, for example, SPI. You can have register communication while you are sending data.
- 10 MHz
- No waste of data bits. If you need 18 bit, then you transmit 18, not 24 bits as you would
do with other physical layers.
- Integrated error / warning mechanism
- Possibility of chaining sensors serially. In this case, all data of all sensors are latched
at the first master clock rising edge.
- Data with CRC.
- Electronic datasheet.
This latter feature is quite interesting. The BiSS master can sniff out what the sensor can do
and configure itself accordingly.
Dora
Different version of the encoder are using different protocols. You need to look at the full part number, -B is BISS, -S SSI and -K RS485. RS485 protocol details are not in the datasheet, there should be an additional manufacturer spec.
You provided the datasheet
Did you read it?
It clearly says:
Refer to the AS33-M42M RS485 software specification document for detailed information.
--> ask the manufacturer for this document.
Klaus
Hi friends,
Thanks in advance!
As I mentioned, There should be another document and I have already asked supplier to provide me such document. still nothing.
Hope that you guys help me out.
thanks in advance.
Hello!
Renesas, not sure.
- 10 MHz
- Data with CRC.
Dora
According to part number of my encoder and also datasheet, I have to use RS485 physical layer.
LaTeX Commands Quick-Menu:
