theboss4
Junior Member level 1
i'm sort-off (been around a few years, but just recently started designing) new to RFIC design. The issue is my gilber mixer design has a higher 2nd order spur (2xRf) on the output, much higher than is expected, since typically the 2nd harmonic is expect to be >80dBc at the mixer output. I'm trying to isolate the source of the 2nd harmonic by (1) using an ideal LO source (tried it but didn't see that much degradation in the problem spur) and (2) using a ideal mixer RF stage (not sure how best to do this - will appreciate any help on this part). the mixer design is attached: need help with RF stage design, is the any reason why it would produce high second order spur? what about an ideal source?
