xorcise
Full Member level 2
need led display
Then what are you talking about if not driving an LED Matrix? Do the math.... 640 x 480 x RGB = 80 x 60 of these blocks would be required. I have 48mm and 60mm RGB blocks, so that would easily become a VERY large display.
Also, your approach is too electrically simplistic. Firstly, your drawings (the ones I can see here in the forum) don't show a matrix configuration. Next, your circuit with the FET's cannot work due to the fact that each color LED has a different Vf. You would try to turn all 3 on at the same time and only one will light.
manish12 said:here is the projected RGB LED matrix board ,
all R , G and B LED terminals shorted and driven by same signal.
picture clear you more !
