mlefter
Newbie level 3
Hello everyone,
I'm trying to simulate some Xilinx VHDL design with GHDL. Unfortunately I have some problems. I am using GHDL 0.28 and Xilinx Webpack 11.3. Here is how I try to do it.
I got the post-synthesis file - 'temp_synthesis.vhd' which starts like this:
library UNISIM;
use UNISIM.VCOMPONENTS.ALL;
use UNISIM.VPKG.ALL;
I've copied the 'unisim_VCOMP.vhd' and 'unisim_VPKG.vhd' files from ../Xilinx/11.1/ISE/vhdl/src/unisims into a new created folder. I've added there also the 'temp_synthesis.vhd" and the test bench ('temp_tb.vhd'). I've also created the unisim and work subfolders.
Now the commands that I use:
$ghdl -a --work=unisim --workdir=unisim --ieee=synopsys -fexplicit unisim_VCOMP.vhd
OK
$ghdl -a --work=unisim --workdir=unisim --ieee=synopsys -fexplicit unisim_VPKG.vhd
OK
$ghdl -a --work=work -Punisim --workdir=work --ieee=synopsys -fexplicit temp_synthesis.vhd
OK
$ghdl -a --work=work -Punisim --workdir=work --ieee=synopsys -fexplicit temp_tb.vhd
OK
Here comes the problem. When I do:
$ghdl -m --work=work -Punisim --workdir=work --ieee=synopsys -fexplicit temp_tb
I get a lot of warnings like:
temp_synthesis.vhd:56:14:warning: (in default configuration of temp(structure))
temp_synthesis.vhd:5031:3:warning: component instance "so_rout_mask_3_and00001" is not bound
temp_synthesis.vhd:5041:3:warning: component instance "so_rout_mask_2_and00011" is not bound
temp_synthesis.vhd:5051:3:warning: component instance "so_rout_mask_2_and00001" is not bound
temp_synthesis.vhd:6745:3:warning: component instance "state_fsm_ffd1_in_sw1" is not bound
It looks like no component is bound. What do the warnings mean? Any clue about possible solutions? My objective is to find out whether it's possible to perform timing simulations with GHDL & Xilinx. Can anyone enlighten me?
Thanks,
Mihai
library UNISIM;
OK
OK
OK
OK
Thanks,
Mihai
