Tarun Parihar
Newbie level 2
Fatal Error : Missing MOSFET model definition for "NMOS25"
: Referenced by device(s):
: MNMOS_2_5v_1
Fatal Error : Missing MOSFET model definition for "PMOS25"
: MPMOS_2_5v_1
already try this procedure too
Follow these steps:
Go to setup-->Spice simulation
Select General on the left pane.Under Files and Directories on the right side,you will find an option called Library files.
Click on browse, select your model library file ( *lib) and then press OK.You need to add "tt" or "tm" at the end after including the library file. So finally that column will look like...
../../../Tanner EDA/Tanner Tools v14.1/Libraries/Models/Generic_025.lib tt
but getting stiil error that
File not exported????:?:
Plz helppp
: MNMOS_2_5v_1
: MPMOS_2_5v_1
Follow these steps:
Plz helppp
