Generation of N bit random bit stream in verilog
envyh123
Newbie level 3
Newbie level 3
I dont want to generate it using LFSR, i want to use $random function of verilog to generate a random 8 bit data stream. I have generated random integer from 0 to 255 using the following code.
Can anyone suggest methods to convert this into 8 bits
My code :
Code Verilog - [expand]
8
9
initial
begin
integer num;
repeat(100) @(posedge clock)
begin
#2;
num<=$urandom_range(255,0);
end
end
hi,
" $urandom " system verilog not verilog.
.you can put something like this
value <= num[7:0];
so first 8 bits will be stored into value.
regards
Did you mean to ask how to serialize an 8-bit value into a stream of 1-bit values?
bit signal;
initial repeat (100)
           begin
             bit [0:7] num;
             num = $urandom;
             for(int i=0;i<8;i++)
              @(posedge clock)
                 signal <= num[i];
           end
