modelsim saif
Hi there,
I've been following the Synopsys Power Compiler UG for SAIF generation using VHDL RTL. However, when I issue the set_toggle_region command ModelSim crashes.
The flow I've been following is:
- read in RTL to dc_shell
- write out a forward-annoted SAIF file for use in ModelSim
- compile the VHDL RTL using vcom
- launch ModelSim linked to the Synopsys DPFLI shared object library
- read in the forward-annoted SAIF file using read_rtl_saif
- try to set the toggle region using the set_toggle_region command
and ModelSim crashes as I issue the set_toggle_region command.
So far my theory on the crash is based on the fact that the forward-annotated SAIF file doesn't match the naming once the design is read into ModelSim. For example, I have generate statements replicating module instances and the way Synopsys and Mentor unroll the generate statements differs. In my forward SAIF file I have u_dut/u_datapath_0, whereas in ModelSim I have u_dut/generate_datapath__0/u_datapath.
Could the crash be caused by the DPFLI getting in a twist trying to annotate the forward SAIF?
Has anyone successfully used the DPFLI flow for VHDL RTL SAIF generation?
Thanks.
