N
Nitesh Annabhimoju
Anyone out there, please help me to Generate Bubble sorting for 8-bit in VHDL using structural mode by using the attached file.
View attachment code.docx.pdf
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity bubble is port (S1 : in std_logic; south_b : in std_logic; north_b : in std_logic; data_out : out std_logic_vector(7 downto 0)); end bubble; architecture bubble_sort of bubble is type memory is array (1 to 5) of std_logic_vector(7 downto 0); begin SORT : process(S1,south_b,north_b) variable rami : memory := ("00000001","00000010","00000100","00001000","00010000"); rami( 1) := "00000100" ; rami( 2) := "00010000" ; rami( 3) := "00000100" ; rami( 4) := "00100000" ; rami( 5) := "10000000" ; constant ramo : memory := rami ; variable t1,t2: integer; variable tmp : std_logic_vector(7 downto 0); variable x : integer := 1; variable y : integer := 1; begin for i in 1 to 5 loop t1 := 6; while t1 > i loop t2 := t12; t1 := t11; if(t1 >= 2) then if rami(t1) < rami(t2) then tmp := rami(t1); rami(t1) := rami(t2); rami(t2) := tmp; end if; end if; end loop; end loop; if (S1 = '1') and (south_b = '1') then data_out <= rami(5); x := 4; elsif (S1 = '1') and (north_b = '1' )then data_out <= rami(x) ; x := x1; if (x = 0) then x := 5; end if; end if; if (S1 = '0') and (south_b = '1') then data_out <= ramo(1); y := 2; elsif (S1 = '0') and (north_b = '1' )then data_out <= ramo(x) ; y := y+1; if (y = 6) then y := 1; end if; end if; end process SORT; end bubble_sort;
