Generating base audio clocks with Spartan 6 (PLL?)
robiwan
Junior Member level 2
I have a Spartan 6 clocked with 100 MHz (Atlys) and I want to generate the base audio clocks 22.5792 MHz and 24.576 MHz (or some multiple of them). For Fclk/3125 = Fvco/768 I would get Fvco = 24.576 MHz, but this would mean the PLL frequency is 32 KHz. Reading the specs this seems a much to low frequency, both for the VCO and the PLL. Ideas ? :smile:
are you syre you need to generate this clock, is it not generated by the AC codec device ?
Yes, I'm sure. The DAC I'm using is the TI PCM4104. I.e. I'm not using the onboard AC codec, this is for driving a prototype board with the PCM4104.
you still can use it (the ac codec' bit_clk) as a system clock, this is the best option,
unless you have other clock sources beside the 100mhz.
Indeed. You're right. The BITCLK is an output in LM4550 primary codec mode, and I should be able to generate the 24.576 MHz clock from it. However I still need the 22.5792 MHz clock, and yet again it seems that the PLL is too limited for this. Ah well, I can always add two external crystal clocks also. No need to force the square peg into the round hole...
you can generate the clock by chaining 3 pll together...
since 100/22.5792 = 7^2*3^2*2^3/5^6 - you can divide it to 3 plls....
I think if you use 2xPLLs (for each frequency) + DCM you are able to generate 24.576:
PLL1 x8, /25 = 32 MHz, PLL2 x24, /125 = 6.144 MHz (=24576/4)
Yes, thank you, and with one extra PLL3 x147, /160 = 5.6448 MHz (=22579.2/4). Then 2 DCMs are used to do the final x4 (2*2) ?
you cannot do this kind of pll divisions in spartan 6 you will need more pll., as i wrote before :
7^2*3^2*2^3/5^6 = 49/25 * 4/25 * 8 /25 = 22579.2
you will need extra pll for the 24.576 calculation.
in any case output jitter levels will be high.
Additionally of what aruipksni says, all the multiplications should not exceed 1000 MHz on spartan-6 (values can vary depending of speed grade).
So, in each PLL, you should check if multiplication does not exceed this limit. And yes, DCM was intended for x4 multiplication (but I did not take jitter into account).
I was about to mention the same thing. Yes you can chain pll's, but before you go too far with this in your project best calculate + verify jitter first. That way you can check your favorite datasheets if it's going to be a problem.
