Generating 500Mhz sinusoidal from 100Mhz square wave
voho
Full Member level 2
Nador City
Hi all,
i have a quartz at 100MHz square wave i want to generate 500MHz sinusoidale at output wich component or circuit can do this????
thank s in advance
regards
Re: in 100Mhz out 500Mhz
PLL can do that ..
See some details here:
Regards,
IanP
Use PLL with a sinusoidale VCO.
You should already have your 500MHz sinwave if you have a 100MHz square wave since 500MHz sine is a component of 100MHz square wave(review fourier series). If you would like to filter out the other harmonics, pass the the 100MHz square wave though a bandpass filter with fo=500MHz.
