Generating +12v and -12v from 24v
polus
Junior Member level 2
I need to be able to generate +12 and -12v from a 24v supply. Can anyone prod me in the direction of a stable cost effective method?
Much Appreciated!
One option is so called "virual ground" ..
https://tangentsoft.net/elec/vgrounds.html
Without going into details, it is like dividing the input voltage into 2 identical halves ..
If, however, you need (or prefer) to keep the same ground as the input voltage, you will have to use a step-down voltage converter (linear od switching) to produce +12V and a dc-dc converter to generate -12V of +24V or of +12V ..
Regards,
IanP
    polus
Ok, Thanks Ian.
Its a cost saving issue. The system has 24v, 12v, -12v and 5v. Buying a powersupply with these is resonably expensive and Im sure theres way to just have a standard 24v supply and then have a small amount of analogue circuitry to supply the voltages.
I look into the terms you have used :)
Dear,
Such as Ian I think you should use DC/DC Converters.
Take a look at attached Datasheet.These DC/DC converters are available @ Farnell.
(they are also available at higher power/Current)
Good Luck.
