Your Gerber setup file is incorrect. Because you selected the SMD pads and thru hole pads, you're getting the teardrops that are added in the routing program.
In the setup contents screen for the soldermask top, select "none" in the "layer" section.
Over in the "board Items" section, select "Soldermask Top", and hold down the shift key and select "board outline" if you want that included.
This will only plot out the soldermask top pads that are added in the padstack editor, plus the soldermask top drawing layer where you can add text if you want, and the board outline if selected.
You would do the same procedure for bottom soldermask. Also top and bottom solderpaste levels are similar.
