General Assembly query on layout
n_raghavan07
Junior Member level 3
Bangalore
sot23 +wave soldering
Assembly query (Please mention the IPC or other standard when answering)
1. How components are selected for reflow and wave soldering based on what basic.
2. Is there any pad geometry difference between reflow and wave soldering?
3. How through hole components will be assembled through automated placement
4. How thermal spokes are adjusted if it is not present.
5. How to calculate axial through hole pin pitch
6. How to decide the direction of the PCB assembly.
7. Why component placement direction on board is important
8. What is making the constraint to placing heighted component on the bottom?
9. What is selective wave soldering?
10. How machine understands the polarity for the polarized parts.
11. If I know in the hole board only one section of board is using SMD pad. So is it will fine I generate the stencil for the particular are instead of generating it for the whole board.
12. What should be the heighted component to fiducail distance?
13. Is pin no marking is required for transistor (sot23)
14. How assembler will identify the no of assembly cycle of board
15. What is the use of flex and paste in PCB assembly
16. Will be there any component orientation manipulation at the time of placing the component using automated assembly.
Regards,
N.Raghavan
n_raghavan07@yahoo.com
transistor pin numbering direction sot23
plz find attached answers .If any doubt plz get back to me
wave will be for through hole& SMD both while reflow will be only for through hole comp.Its based on cost of project since reflow is costlier than wave.
yes..size of pad will be more in wave
It can be done in advance setups where Robotic machines can be use for assembly
Not sure but it involves CAM activity at fabrication plant and in CAM activity u can do anything not only spokes adjustment
length of body+4mm
It can be any direction,generally longer axis
that is for soldering purpose.
not required,it depends on mechanical of project
that is hand soldering of components
i feel we need to set the program in machine
No idea
more than 3R
no
no idea
for soldering
can be for selective comp,provide ease in assembly
automatic assembly layout
Yes, Stencil is used for fine pitch pads <0.5mm
And for wave soldering,we should place the foot print pads perpendicular to the wave soldering directions.we should not place smd components near to heighted through hole components.
cheers
chakri
placing smd components in layout
"And for wave soldering,we should place the foot print pads perpendicular to the wave soldering directions.we should not place smd components near to heighted through hole components".
I agreed with Chakri .As mentioned above it is called Shadow effect
sot23 wave direction
What is the Min distance between BGA to BGA and BGA to other devices for the Large, Medium and module (SMD level –A, B and C) as per IPC? .If any one can provide guidelines or guidelink it would be more helpful.
Thanks and Regards,
N.Raghavan
