sot23 +wave soldering
Assembly query (Please mention the IPC or other standard when answering)
1. How components are selected for reflow and wave soldering based on what basic.
2. Is there any pad geometry difference between reflow and wave soldering?
3. How through hole components will be assembled through automated placement
4. How thermal spokes are adjusted if it is not present.
5. How to calculate axial through hole pin pitch
6. How to decide the direction of the PCB assembly.
7. Why component placement direction on board is important
8. What is making the constraint to placing heighted component on the bottom?
9. What is selective wave soldering?
10. How machine understands the polarity for the polarized parts.
11. If I know in the hole board only one section of board is using SMD pad. So is it will fine I generate the stencil for the particular are instead of generating it for the whole board.
12. What should be the heighted component to fiducail distance?
13. Is pin no marking is required for transistor (sot23)
14. How assembler will identify the no of assembly cycle of board
15. What is the use of flex and paste in PCB assembly
16. Will be there any component orientation manipulation at the time of placing the component using automated assembly.
Regards,
N.Raghavan
n_raghavan07@yahoo.com
