Gate Driver Circuit for MOSFET, Slow Turn Off?
digi001
Full Member level 5
If I am using a MOSFET to interrupt high-current and would like the switch to turn off slowly in order to reduce a voltage spike....what kind of circuit would be required for this?
A negative-going ramp voltage instead of a rectangular one as the gate switching voltage. One possible method would be a large resistor in series with the gate so that the gate charge will not drain too quickly. A steering diode in parallel with the resistor will avoid slow turn-on.
Reactions: digi001
    digi001
