GaN VHF Broadband Power Amlifier
Andrew77
Member level 5
Member level 5
Rome
GaN VHF Broadband Power Amplifier
I'm designing a 20-500 MHz power amplifier (100W)with GaN technology @ 28V Vdrain. I'm not sure if using 2 transistor in a push-pull configuration or using 1 transistor and microstrip, considering that GaN has a higher in-out impedances than LDmos. I'm thinking of using CREE or Nitronex devices,
any suggestion?
Thanks
Andrea
Well, good luck. These devices do have very low output impedances, so building a transformer over that bandwidth will be challenging.
Maybe you could do something unique and combine the output impedances in series somehow with a stackup. Lets say one device has 5 ohms output impedance. If you could design a structure to connect 5 of those outputs in series, you would have a 25 ohm impedance to match to the 50 ohm output. At these lower frequencies, maybe it could be done.
Hello Biff44,
you say: "combine the output impedances in series....If you could design a structure to connect 5 of those outputs in series..." how it could be possible? The final stage must not have more than two transistors otherwise I buy the amplifier
Hello Andrew77,
For this kind application, in NXP website there is a 120W application note with BLF645 from 10mhz to 600mhz, maybe you can take it as reference.
if i wanna use the 145 MHz frequency
What do I need to set??
please help me
Regard:
_haryo_
