stanleystan
Banned
- Joined
- Apr 26, 2014
- Messages
- 59
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 8
- Activity points
- 0
Gain Measurement Test:
Step#1.) Set the input voltage either AC or DC at the nominal input voltage and measure the output voltage
Step#2.) Now set the input voltage to Half of the nominal input voltage and measure the output voltage
Step#3.) Now set the input voltage to double of the nominal input voltage and measure the output voltage
The Ratio for each step1 thur step3 would all have the same ratio gain? true or false?
The Gains Ratio should be the same if the input voltage is half or double the nominal input voltage?
What kind of gain measurement test is this called?
Why would a tech do this type of test for what application?
Does this test actually tell you if the gains of each stage is working and all the op amps are working? the resistor and cap values are in tolerance?
If the circuit under test has multiple parallel paths and feedback paths would this gain measurement test still work?
Having parallel paths on the input or output of gain stages would add or subtract to the gain ratio of the gain stage? this would change the gain input and output ratio depending on the inputs voltage?
