engr.ja
Hi All,
I made a modified version of **broken link removed** with 3 endpoints. For CDC out endpoint i want manual commit so that i can also send data to fpga. But manual commit is not sending data to fpga but automatic commit is working. Nothings seems wrong. Here is the code. I will really appreciate some feedback.
void TD_Init(void) // Called once at startup
// Return FIFO setings back to default just in case previous firmware messed with them.
SYNCDELAY; PINFLAGSAB = 0x00;
SYNCDELAY; PINFLAGSCD = 0x00;
SYNCDELAY; FIFOPINPOLAR = 0x00;
// Global settings
SYNCDELAY; REVCTL = 0x03;
SYNCDELAY; CPUCS = ((CPUCS & ~bmCLKSPD) | bmCLKSPD1); // 48MHz
// IFCLKSRC 3048MHZ IFCLKOE IFCLKPOL ASYNC GSTATE IFCFG1 IFCFG0
SYNCDELAY; IFCONFIG = 0xE3; //1110 0011
// EP1OUT & EP1IN
SYNCDELAY; EP1OUTCFG = 0x00;
SYNCDELAY; EP1INCFG = 0xA0;
// VALID DIR TYPE1 TYPE0 SIZE 0 BUF1 BUF0
SYNCDELAY; EP2CFG = 0xA2;
SYNCDELAY; EP4CFG = 0xE2;
SYNCDELAY; EP6CFG = 0xD0;//1101 0000
SYNCDELAY; EP8CFG = 0x00;
// 0 INFM1 OEP1 AUTOOUT AUTOIN ZEROLENIN 0 WORDWIDE
SYNCDELAY; EP2FIFOCFG = 0x00;
// SYNCDELAY; EP2FIFOCFG = 0x10;
SYNCDELAY; EP4FIFOCFG = 0x0C;
SYNCDELAY; EP6FIFOCFG = 0x0C;
SYNCDELAY; EP8FIFOCFG = 0x00;
SYNCDELAY; EP4AUTOINLENH = 0x02;
SYNCDELAY; EP4AUTOINLENL = 0x00;
SYNCDELAY; EP6AUTOINLENH = 0x02;
SYNCDELAY; EP6AUTOINLENL = 0x00;
SYNCDELAY; FIFORESET = 0x80;
SYNCDELAY; FIFORESET = 0x82;
SYNCDELAY; FIFORESET = 0x84;
SYNCDELAY; FIFORESET = 0x86;
SYNCDELAY; FIFORESET = 0x00;
SYNCDELAY; OUTPKTEND = 0x82;
void TD_Poll(void) // Called repeatedly while the device is idle
if( !( EP2468STAT & 0x01 ) )
{ // EP2EF=0 when FIFO NOT empty, host sent packet
OUTPKTEND = 0x02; // SKIP=0, pass buffer on to master
if (!(EP1INCS & 0x02)) // check if EP1IN is available
EP1INBUF[0] = 0x0A; // if it is available, then fill the first 10 bytes of the buffer with
EP1INBUF[1] = 0x20; // appropriate data.
EP1INBUF[2] = 0x00;
EP1INBUF[3] = 0x00;
EP1INBUF[4] = 0x00;
EP1INBUF[5] = 0x00;
EP1INBUF[6] = 0x00;
EP1INBUF[7] = 0x02;
EP1INBUF[8] = 0x00;
EP1INBUF[9] = 0x00;
EP1INBC = 10; // manually commit once the buffer is filled
