Full Bridge driver with UCC28C43
Z
zenerbjt
We wish to use UCC28C43 to drive a Full Bridge.
The attached shows it in LTspice.
Can you think of a more lower-component-count way of doing this?
  • LT1243 as half bridge driver 2.txt
To reduce component count, you'll use a dedicated push pull controller IC.
Reactions: zenerbjt
    Z
I suppose my schematic has a similar parts count. Same as your schematic mine has a D flip-flop performing clock-divide-by-2 (it's the easiest way I've seen to derive twin interleaved pulses). Duty cycle can be varied by a single adjustment to the incoming pulse train.
Reactions: zenerbjt
    Z
Thanks, there are very few of these with a 1Volt Current sense pin which is good for CST connection.
It amazes me how few suitable push pull controllers exist for this.....there is LTC3723, but current sense threshold is very low and its very expensive.
neither your schematic nor your description tells that you want current sense features.
Why now a different requirement?
Klaus
Reactions: zenerbjt
    Z
The attached is the best so far, any improvements?
Full Bridge drivers are surprisingly hard to find with the versatility of the UCC28C43.
LTspice sim and pdf schem attached
  • Full Bridge with UCC28C43 _A.TXT
  • Full Bridge with UCC28C43 _A.pdf
You may observe in your simulation how a transformer (inductor) wants to continue conducting current when it's abruptly shut off. It may result in spikes, or even reverse current flow.
You may need to add a snubber network, or modify gating waveforms, try soft switching, etc.
Reactions: zenerbjt
    Z
