FTDI 2232 example code
jose12
Newbie level 1
ftdi 2232
am new to this.
can someone provide a very simple example to programe the FTDI 2232 in FIFO mode. Like sending a byte(s) to the 2232's ports over USB from a PC.
ftdi2232
the FTDI 2232 chip creates serial port 'from usb port'. it means that instead of communicating via usb, after connecting your circuit with ft2232 you can communicate with it as by serial port.
so communication from uC is simple uart transmission, and from PC either, depends on in which language you code
