I have built a project the uses the FT232R USB to serial converter. My project is mains powered and is working fine but I keep worrying that if I plug my project into different computers and laptops that the ground between my project and the PC could be at a different level.
Is this possible or even likely to happen? or will the PC USB ground always the same level as my mains powered device?
Looking at the FT232R data sheet, there is no provision for this but I keep thinking that if for some reason the ground on the PC USB is higher or lower, I will get a current flowing through the USB cable and into my project, maybe blowing it up or something. 8-O
