asicganesh
Member level 3
I want to design a FSM that has to handle the below scenario:
1. A continuos stream of packets arrive with a start of Frame
2. As soon as Start of Frame is received.. I have to send it to the internal block until End of Frame is got..
3. If instead of End of Frame I get Start of Frame again I have to delete the frames got in between..
4. No FIFO or Memory should be used.
5. Frame is continuos from start to end.. no handshake.. no storage is possible.. and can be of any length..
Any idea? I want a bubble diagram for this case
