Front Panel Design in LabVIEW
mohan_mithai
Banned
Newbie level 6
hi members
I m going to make one DAQ system for measurement of temperature and pH...in which i m going to use NI product..the card numbers are 9211, 9201, 9203....which are analog input card...
Now as I m a new user in labview...i need a help from u expert members...
I want to design one front panel in which i would like to show 3 individual buttons for that..when i select a temperature button on front panel at the same time I required to display 4 individual waveform charts which will show the acquire data on screen...or say temeparature or pH..
I had tried to make the same VI which i m attaching here...i need help from members to complete the VI...u plz suggest me all corrections or send me some good files which will guide me in the to make my front panel design as well block diagram for the same...
how can i make the front panel for the same.......plz advise me
Mohan
Hi !
I didn't download your code, but I can advis you to do so:
For every button attach a case structure. Within the case structure you can develop any fonction (code) you want.
instead of using a simple button, you can also use the "enum" and a case structure.
Let me know if that helped.
Regards
LaTeX Commands Quick-Menu:
