Teakthecat
Newbie level 1
Hi everyone,
I'm in a crunch with too much on my plate to figure this one out on my own, so I would appreciate any info with this design.
I need a small(ish) unit that we can use on a couple different machines here. The signal pulses count number of turns of a shaft, which is then translated to speed and distance travel. We have two different variants of machines right now. The first uses the pulses as they are and fed to the microcontrollers, and other systems in the machine. We now have a second variant which unfortunately uses a different gearbox, therefor the pulse counts don't translate properly.
If we can have a unit that with a control signal will allow either the frequency to pass through unchanged or "modified" then we can use same controllers, wiring, etc.
Requirements:
Control Signal:
Thanks in advance for any help here.
Pat
Requirements:
Supply voltage 10 to 32 Vdc
Current consumption 15mA max
Fin and Fout signal duty cycle 50 to 60%
Fin range DC to 2.1 KHz
Fin max 14Vp-p
Fout square wave 0 to 5 V +/- 0.5V
Temperature range -40 to +120*C
Fin max 14Vp-p
Control Signal:
If Control signal is equal to Supply voltage than Fout=Fin/0.860
If Control signal is equal to 0V or open than Fout=Fin
Pat
