paul0
Newbie level 5
Hi all,
I have a problem using my frequency dividers :
1) the frequency divider consist of a schmitt trigger, filtering capacitors, and a flipflop(HC74)
2) the dividers are connected as described in the figure below : Common Vdd, Common Gnd from power supply 3.3V 6A
problem
1) When I use a single power supply for the 3 dividers the required division precision is totally lost only 1 measure on 3 works ( Note that the maximum current of the power supply is 6A at 3.3V)
2) When I use separated power supply for each dividerI got my measures and all the 3 circuits works well
What I suspect
1) there may be a noise coming from the ground of the frequency meter or the mux ??
2) I should (may be) connect some pull down resistor at the output of each divider ??
If anyone have some ideas I will really appreciate,
Thank you for help
problem
What I suspect
Thank you for help
