ERROR:Pack:2310 - Too many comps of type "BUFGCTRL" found to fit this device.
ERROR:Map:115 - The design is too large to fit the device. Please check the
Design Summary section to see which resource requirement for your design
exceeds the resources available in the device. In particular check the
non-slice resources since the slice counts may reflect the early termination
of the flow.
NOTE: An NCD file will still be generated to allow you to examine the mapped
design. This file is intended for evaluation use only, and will not process
successfully through PAR.
